跳转到主内容
How to Add a Hole to a Belt
你所需要的
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: 步骤 1 中的图像 1,1
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: 步骤 2 中的图像 1,2 How to Add a Hole to a Belt: 步骤 2 中的图像 2,2
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: 步骤 3 中的图像 1,1
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: 步骤 4 中的图像 1,2 How to Add a Hole to a Belt: 步骤 4 中的图像 2,2
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: 步骤 5 中的图像 1,2 How to Add a Hole to a Belt: 步骤 5 中的图像 2,2
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: 步骤 6 中的图像 1,2 How to Add a Hole to a Belt: 步骤 6 中的图像 2,2
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
结论
After you complete the final step to your liking the fix is done.
另外一个人完成了本指南。
Alexa Velazquez
于03/22/21注册
160 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 90
总计 2,294
