跳转到主内容
How to Add a Hole in a Leather Belt
你所需要的
  1. How to Add a Hole in a Leather Belt, How to Add a Hole in a Leather Belt: 步骤 1 中的图像 1,1
    • Make sure the leather belt is clean by wiping it down with water and drying it before working on it beforehand to get rid of any excess dirt or grime.
  2. How to Add a Hole in a Leather Belt: 步骤 2 中的图像 1,1
    • Find a flat and durable surface to work on, preferably a wooden work table. If that’s not available, then use a good sized wooden block to work on.
  3. How to Add a Hole in a Leather Belt: 步骤 3 中的图像 1,1
    • Using a measuring tape, measure the distance between each of the existing holes to figure out the distance to place your new hole.
  4. How to Add a Hole in a Leather Belt: 步骤 4 中的图像 1,1
    • Mark where you want the hole with either a pen or indent using the pin punch. Mark as many as you see fit before continuing onto the next step.
  5. How to Add a Hole in a Leather Belt: 步骤 5 中的图像 1,1
    • Align the pin punch where you marked the hole.
    • Make sure to tighten the grip on the pin before hammering onto the marked area. Continue this for all the other hole marks.
  6. How to Add a Hole in a Leather Belt: 步骤 6 中的图像 1,1
    • Push the pin all the way through the hole to make sure the hole is fully formed.
  7. How to Add a Hole in a Leather Belt: 步骤 7 中的图像 1,1
    • Clean off any stray leather bits left from the hole placement using a razor blade.
结论
Once you complete all your steps, make sure to congratulate yourself on your new belt! Now you can hold up anything you need without any issues.
Feliza Castillo
于05/24/23注册
195 声望
撰写一个指南
团队
York University, Team A-2, Allen Summer 2023 York University, Team A-2, Allen Summer 2023 的会员
YORK-ALLEN-SU23SAG2
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 42
总计 748
