跳转到主内容
How to Add Privacy to a Wood Fence
你所需要的
  1. How to Add Privacy to a Wood Fence, How to Add Privacy to a Wood Fence: 步骤 1 中的图像 1,1
    • After buying my home, I realized that anybody could walk by my back fence and look right into my backyard. I'm sure I'm not the only one who feels a little uneasy about such a lack of privacy.
  2. How to Add Privacy to a Wood Fence: 步骤 2 中的图像 1,1
    • To add privacy and provide stability to an older fence, I headed to my local hardware store and bought a few fence boards. The boards pictured cost $3.85 a board and, depending on how tall you need your boards cut, one fence board provides approximately three privacy boards.
  3. How to Add Privacy to a Wood Fence: 步骤 3 中的图像 1,2 How to Add Privacy to a Wood Fence: 步骤 3 中的图像 2,2
    • Once I purchased my boards, it was time to cut them. I used a miter saw, but a hand saw works just fine. In order to find the length of your privacy boards, measure from the top rail of your existing fence to the future height that you would like to extend your fence.
  4. How to Add Privacy to a Wood Fence: 步骤 4 中的图像 1,2 How to Add Privacy to a Wood Fence: 步骤 4 中的图像 2,2
    • Once you have your measurement, mark your board (measure twice, cut once) and then make your cut.
  5. How to Add Privacy to a Wood Fence: 步骤 5 中的图像 1,3 How to Add Privacy to a Wood Fence: 步骤 5 中的图像 2,3 How to Add Privacy to a Wood Fence: 步骤 5 中的图像 3,3
    • After you mark the board in order to notch it, move your miter saw to a 45 degree angle to make the first cut.
    • Then flip the board and shift the saw to make the second cut.
  6. How to Add Privacy to a Wood Fence: 步骤 6 中的图像 1,1
    • You should now have a board that is ready to be installed (I suggest doing as many as you need and then installing them rather than doing one at a time).
  7. How to Add Privacy to a Wood Fence: 步骤 7 中的图像 1,2 How to Add Privacy to a Wood Fence: 步骤 7 中的图像 2,2
    • Using a drill and screws (any screws will work, but for aesthetics, I suggest deck screws). I use a four-screw pattern simply for looks and stability, but it is up to you how you would like to attach your new privacy boards.
  8. How to Add Privacy to a Wood Fence: 步骤 8 中的图像 1,1
    • Voila! Your backyard has transformed into a personal/private oasis. Congratulations! Enjoy your newfound security and privacy (plus it was cheap).
结论
This is a fun and easy weekend project, so if you have little ones around that you are trying to teach creativity or woodworking to, have them help out. Remember, safety should be your #1 priority. Enjoy.
4等其他人完成本指南。
Brett
于02/19/15注册
236 声望
撰写一个指南
团队
CSU Stanislaus, Team 1-2, Moberly Winter 2015 CSU Stanislaus, Team 1-2, Moberly Winter 2015 的会员
CSUS-MOBERLY-W15S1G2
4 名成员
创作了1篇指南
一条评论
Great idea, for added privacy & security.
Jose - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 22
过去 30 天: 61
总计 6,668
