跳转到主内容
How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban
你所需要的
  1. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban, How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 1 中的图像 1,1
    • Locate the wiring harness bundle, which exits the firewall underneath the brake booster.
  2. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 2 中的图像 1,1
    • Identify the auxiliary wire, which is folded and taped to either the wiring harness or the fire wall.
  3. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 3 中的图像 1,1
    • Use a knife to cut the tape away from the wire and unravel it.
  4. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 4 中的图像 1,1
    • Run the wire against the battery box.
  5. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 5 中的图像 1,3 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 5 中的图像 2,3 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 5 中的图像 3,3
    • Place the ring terminal (washer end) of the wire on the right post located at the front of the battery.
    • Place the 10 mm washer on the post.
    • Tighten the washer using a 10 mm wrench, crescent wrench, or pliers.
    • Post size and location may vary slightly in different models. The washer will fit snuggly around the correct post.
  6. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: 步骤 6 中的图像 1,1
    • After hooking up the wire, check to make sure the 40 amp fuse is installed for the auxiliary pin.
    • If the fuse is not installed, there will be an empty space. This fuse can be purchased at any automotive shop.
终点
13等其他人完成本指南。
Lauryn Johnson
于01/19/16注册
454 声望
撰写一个指南
团队
6条评论
This sends constant power to the trailer. What if I wanted to make that power switched by the ignition so when the key is off I can be confident that the trailer won't kill my truck battery? I know I can just unplug the trailer harness or pull this fuse to stop it, but That might be easy to forget to do.
Eric Wonderlich Jr. - 回复
Eric, did you ever get an answer to your inquiry about killing the power to the trailer when the key is in the off position?
Bobby Burke -
It’s not a break booster, it is a brake booster. If you are going to be an author, you should know the meaning of the words you use.
Albert - 回复
Never fails some troll somewhere..
Garry Foster -
“Words have meaning” geez Cyber Warrior. Tough talk from a distance. ?
nshourds -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 41
过去 30 天: 152
总计 33,454
