跳转到主内容
How to Access the Internal Components of an HP 15-R011DX
你所需要的
  1. How to Access the Internal Components of an HP 15-R011DX, Battery: 步骤 1 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX, Battery: 步骤 1 中的图像 2,2
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. How to Access the Internal Components of an HP 15-R011DX: 步骤 2 中的图像 1,1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX, How to Access the Internal Components of an HP 15-R011DX: 步骤 3 中的图像 2,2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. How to Access the Internal Components of an HP 15-R011DX: 步骤 4 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX: 步骤 4 中的图像 2,2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. How to Access the Internal Components of an HP 15-R011DX: 步骤 5 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX: 步骤 5 中的图像 2,2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. How to Access the Internal Components of an HP 15-R011DX: 步骤 6 中的图像 1,3 How to Access the Internal Components of an HP 15-R011DX: 步骤 6 中的图像 2,3 How to Access the Internal Components of an HP 15-R011DX: 步骤 6 中的图像 3,3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. How to Access the Internal Components of an HP 15-R011DX: 步骤 7 中的图像 1,2 How to Access the Internal Components of an HP 15-R011DX: 步骤 7 中的图像 2,2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
结论
2等其他人完成本指南。
Ethan Guillotte
于03/20/19注册
517 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 587
