跳转到主内容
How to Fix A Loose Bicycle Chain
你所需要的
  1. How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: 步骤 1 中的图像 1,2 How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: 步骤 1 中的图像 2,2
    • Determine if your chain is loose. As shown in the pictures, the bike chain is hanging low; this is an excellent indication that your bike chain is loose.
    • Your bike might have oil all over its chain and gear, so it's best to wear gloves.
  2. How to  Fix A Loose Bicycle Chain: 步骤 2 中的图像 1,1
    • Use a bike stand or wall to help keep your bike from falling.
  3. How to  Fix A Loose Bicycle Chain: 步骤 3 中的图像 1,2 How to  Fix A Loose Bicycle Chain: 步骤 3 中的图像 2,2
    • Loosen both nuts on either side of the rear wheel using a socket wrench, rotating the wrench from left to right.
    • Be sure to not fully unscrew the nut or else the rear wheel will no longer be connected to the bike and you will have to spend time reassembling it.
  4. How to  Fix A Loose Bicycle Chain: 步骤 4 中的图像 1,2 How to  Fix A Loose Bicycle Chain: 步骤 4 中的图像 2,2
    • Hold the end of the bike wheel with one hand and the bike's frame with your other hand.
    • Pull the wheel back from the frame.
    • Hold the wheel in place while proceeding to the next step.
    • While holding the wheel back, your chain should stop hanging.
  5. How to  Fix A Loose Bicycle Chain: 步骤 5 中的图像 1,2 How to  Fix A Loose Bicycle Chain: 步骤 5 中的图像 2,2
    • Tighten both of the loose nuts using a socket wrench, rotating the wrench from right to left, while still holding the wheel back.
  6. How to  Fix A Loose Bicycle Chain: 步骤 6 中的图像 1,2 How to  Fix A Loose Bicycle Chain: 步骤 6 中的图像 2,2
    • Check if your chain is still loose. As shown in the pictures, your chain should have more tension making it straight rather than hanging.
    • Do not place your fingers too close to the bike gear. It may accidentally spin depending on how your bike works and trap your fingers.
结论
After reading this guide you will never have trouble with a loose chain again.
5等其他人完成本指南。
Carlos Ortiz
于01/30/22注册
253 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-17, Briggs Spring 2022 CSU Los Angeles, Team 4-17, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S4G17
1 名成员
创作了3篇指南
1指南评论
The steps to tight the loosen chain are good. I will try it for my cycle. https://www.youtube.com/watch?v=JMdihKgC... speed internal gear bicycle). This video reflect your steps in a good manner
Kulasekara Pandian - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 261
总计 29,075
