跳转到主内容
修复你的物品
维修的权力
商店
简介
The boot circuit can be regarded as logic board trigger circuit. To have the phone turned on, working conditions like power supply, clock signal and reset signal are indispensable. What’s more, CPU has to get key components into power-on self-test process and get the bootstrap imported. Since there are so many components involved in the process, reasons for won’t turn on of the phone can also be various.
视频概述
  1. U1000, CPU
    • U1000, CPU
    • This chip is the most important chip on the motherboard. As the central processing unit, It works just like our brain to control every part of our body. So it is responsible for overall control of the phone.
  2. U2700, PMU
    • U2700, PMU
    • PMU here means power management unit. It works just like our heart to keep providing power energy to other components. It provides power supply for working of the boot circuit.
  3. U2600, NAND. It stores data needed for the boot process.
    • U2600, NAND. It stores data needed for the boot process.
    • U3300, Charging IC. It converts battery power supply into main power supply.
    • J3200, battery connector. It makes possible the connection between the battery and the motherboard.
    • U3100, boost IC. It converts voltage when necessary.
    • For a detailed explanation of the boot circuit, you can check out the video here.
Phryne
于2019年11月17日注册
10,421 信誉积分
创作了80篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 29
过去的30天: 108
总计 1,145
