简介
A hole in a knit garment can easily be closed with a needle and thread. All you need is some thread in a matching color so that the repair will be as inconspicuous as possible when you’re finished.
你所需要的
Turn the sweater inside out. Insert the needle through the garment at your starting point at the top of the hole. Pull the thread through until only about 5 cm of thread is overlapping. Before inserting the thread on the other side of the hole, pick up any open stitches so that no other stitches come loose.
Done! You made it.
Done! You made it.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
