跳转到主内容
How do I replace the wheels on my Tobago trolley?
你所需要的
  1. How do I replace the wheels on my Tobago trolley?, Wheels: 步骤 1 中的图像 1,3 How do I replace the wheels on my Tobago trolley?, Wheels: 步骤 1 中的图像 2,3 How do I replace the wheels on my Tobago trolley?, Wheels: 步骤 1 中的图像 3,3
    • Open the trolley and unzip the lining.
  2. How do I replace the wheels on my Tobago trolley?: 步骤 2 中的图像 1,2 How do I replace the wheels on my Tobago trolley?: 步骤 2 中的图像 2,2
    • Unscrew the 4 marked screws with a Phillips screwdriver.
    • When attaching the new wheels, take care not to over tighten the screws.
    • Use the flat-blade screwdriver to remove the 2 washers.
    • Removing the wheelhouse from the trolley.
    • Pinch off the two remaining rivets with the tongs.
  3. How do I replace the wheels on my Tobago trolley?: 步骤 6 中的图像 1,3 How do I replace the wheels on my Tobago trolley?: 步骤 6 中的图像 2,3 How do I replace the wheels on my Tobago trolley?: 步骤 6 中的图像 3,3
    • Remove the other 2 rivets on the outside of the trolley using the flat-blade screwdriver. Then remove the wheelhouse from the trolley.
    • When attaching the new wheelhouse, take care not to over tighten the screws.
结论
Follow the instructions in reverse order to finish the repair.
团队
Vaudesport Vaudesport 的会员
Community
3 名成员
创作了96篇指南
3条评论
Dear Vaude, I have a Module 60 where the airline has managed to snap of a wheel recently. I am in contact with the UK supplier of Vaude parts, but is the repair similar to above and therefore I need to order the right hand side plastic/wheel? Thank you for any help.
JANE D - 回复
Dear Jane, yes, you can use this repair guide also for your Module Trolley. You will get a set of wheels, you so can change both if you want.
VAUDE Reparaturteam -
Dear Vaude
I have a trolley Samoa, and it seems I can't get replacements like for the Tobago. Any idea how I could find wheels to replace the broken ones?
Rollo Launche - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 69
总计 4,920
