跳转到主内容
加入维修社区 - 创建账户
How To True A Bicycle Wheel
你所需要的
视频概述
    1. How To True A Bicycle Wheel, How To True A Bicycle Wheel: 步骤 1 中的图像 1,1
      • Put the rim and align into the truing stand.
      询问修复机器人
      添加评论
    2. How To True A Bicycle Wheel: 步骤 2 中的图像 1,1
      • Second, grab lubricant.
      询问修复机器人
      添加评论
    3. How To True A Bicycle Wheel: 步骤 3 中的图像 1,1
      • Notice how each nipple is void of lube. In this step add the lube to each individual nipple.
      询问修复机器人
      添加评论
    4. How To True A Bicycle Wheel: 步骤 4 中的图像 1,1
      • Once you have completed the previous task, loosen the truing knob.
      • This will make the truing arms open.
      • Give it a spin! The centrifical force lubes up the threads, making it easier to begin truing.
      • Notice the spoke wrenches; they will be required in our next step.
      询问修复机器人
      添加评论
    5. How To True A Bicycle Wheel: 步骤 5 中的图像 1,1
      • Use the truing knob to determine how fine the truing arms (red) need to be. In this case, I am truing finely down to the millimeter.
      询问修复机器人
      添加评论
    6. How To True A Bicycle Wheel: 步骤 6 中的图像 1,1
      • Here the spoke tool (red) will be needed. After giving it a spin, I noticed that it deviated far too much to the left. You will know this by hearing which side scrapes against the truing arm. (orange)
      • Use the spoke wrench (red) to tighten the spokes (yellow). It is good practice to tighten the spoke before and after on the side that needs truing.
      • Lastly, keep truing tire until the range of deviation is good to you. This process for a "quick-fix" can be as little as 30min-1 hour.
      • Experienced cyclists may vary from days to weeks to completely true their tire.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Elijah W
于10/16/23注册
187 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 58
总计 645
