跳转到主内容
How To Start Remote Viewfinder on Samsung WB150F
你所需要的
  1. How To Start Remote Viewfinder on Samsung WB150F, Power on the device: 步骤 1 中的图像 1,2 How To Start Remote Viewfinder on Samsung WB150F, Power on the device: 步骤 1 中的图像 2,2
    • Turn on the device by pressing the button thats labeled POWER on the top.
  2. How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: 步骤 2 中的图像 1,2 How To Start Remote Viewfinder on Samsung WB150F, Finding Remote Viewfinder: 步骤 2 中的图像 2,2
    • Look at the wheel at the top
    • Scroll until the dot is at Wi-Fi
  3. How To Start Remote Viewfinder on Samsung WB150F: 步骤 3 中的图像 1,3 How To Start Remote Viewfinder on Samsung WB150F: 步骤 3 中的图像 2,3 How To Start Remote Viewfinder on Samsung WB150F: 步骤 3 中的图像 3,3
    • Navigate using the Navigation wheel
    • Navigate until the blue glowing square is on Remote Viewfinder
    • Press OK
  4. How To Start Remote Viewfinder on Samsung WB150F, Setting Up: 步骤 4 中的图像 1,1
    • If everything done correctly, You will be on this screen, Time to install the viewfinder app.
  5. How To Start Remote Viewfinder on Samsung WB150F, Finding the app: 步骤 5 中的图像 1,1
    • Search up Remote ViewFinder on App Store/Play Store
  6. How To Start Remote Viewfinder on Samsung WB150F, Downloading the app: 步骤 6 中的图像 1,1
    • When you found the app, Press the download button
    • If it is a cloud, It means it was installed before, You will not need a password to download it.
    • The App Is pretty outdated, I suggest using iOS 4-10, It wont work on newer iOS
    • An iPhone 5c or an iPad 4 works well.
  7. How To Start Remote Viewfinder on Samsung WB150F, Connecting: 步骤 7 中的图像 1,2 How To Start Remote Viewfinder on Samsung WB150F, Connecting: 步骤 7 中的图像 2,2
    • Open up settings and go to the Wifi Tab
    • Connect your device to the cameras wifi.
    • The Wifi name should be the same as on the camera.
  8. How To Start Remote Viewfinder on Samsung WB150F, Starting the application: 步骤 8 中的图像 1,1
    • Launch Remote Viewfinder on your device
  9. How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: 步骤 9 中的图像 1,2 How To Start Remote Viewfinder on Samsung WB150F, Connecting to the camera: 步骤 9 中的图像 2,2
    • Wait until its connected.
    • If you see the screen of your camera Your camera is connected (see step 10 for controls)
  10. How To Start Remote Viewfinder on Samsung WB150F, Controls: 步骤 10 中的图像 1,1
    • Flash
    • Timer
    • Photo Size
    • Zoom
    • Shutter Button
    • Camera View
    • Tap the camera view to hide/show the menu.
结论
Close the app, to disconnect your camera from the app
Artem Ivat
于02/05/20注册
3,549 声望
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 32
总计 1,724
