跳转到主内容
How To Sew With An Awl
你所需要的
  1. How To Sew With An Awl, How To Sew With An Awl: 步骤 1 中的图像 1,2 How To Sew With An Awl, How To Sew With An Awl: 步骤 1 中的图像 2,2
    • Loosen the awl by holding the smooth end and twisting the ridged piece counterclockwise.
  2. How To Sew With An Awl: 步骤 2 中的图像 1,3 How To Sew With An Awl: 步骤 2 中的图像 2,3 How To Sew With An Awl: 步骤 2 中的图像 3,3
    • Insert the needle into the ridged end of the awl, with the eye facing outward.
    • Retighten the awl by holding the smooth end and twisting the ridged end clockwise.
    • Insert the cotter pin into the hole in the smooth end.
    • The cotter pin provides a nice handle for working with the awl.
  3. How To Sew With An Awl: 步骤 3 中的图像 1,2 How To Sew With An Awl: 步骤 3 中的图像 2,2
    • Thread the needle with very thick thread.
    • Align your material. In this case we are resewing the webbing holding a buckle in place.
  4. How To Sew With An Awl: 步骤 4 中的图像 1,2 How To Sew With An Awl: 步骤 4 中的图像 2,2
    • Stab the threaded needle of the awl through all the layers of fabric you are sewing.
    • Thick material is very hard to puncture. Be careful not to puncture yourself in the process.
    • If you are having difficulty puncturing the material, you can use a vice to hold the material in place, or place something on the backside of the material to puncture into. A rubber eraser works great.
  5. How To Sew With An Awl: 步骤 5 中的图像 1,2 How To Sew With An Awl: 步骤 5 中的图像 2,2
    • Pull the short end of the thread through the material, so that it dangles free on the other side of the material.
  6. How To Sew With An Awl: 步骤 6 中的图像 1,2 How To Sew With An Awl: 步骤 6 中的图像 2,2
    • While holding on to the short, free end of the thread, carefully pull the awl back through the material.
    • The short, free end of the thread should stay on the other side of the material.
    • Continue holding the short, free thread, and puncture the material again a short distance away, moving along the material you are sewing.
    • This distance will become a stitch. Try to keep your stitch length short and even.
  7. How To Sew With An Awl: 步骤 7 中的图像 1,3 How To Sew With An Awl: 步骤 7 中的图像 2,3 How To Sew With An Awl: 步骤 7 中的图像 3,3
    • Pull the thread from the eye of the needle, creating a loop.
    • Put the short, free end of the thread through the loop you just created in the thread.
  8. How To Sew With An Awl: 步骤 8 中的图像 1,2 How To Sew With An Awl: 步骤 8 中的图像 2,2
    • Holding the short, free end of the thread taught, pull the awl back out through the material.
    • Pull both ends of the thread taught.
  9. How To Sew With An Awl: 步骤 9 中的图像 1,3 How To Sew With An Awl: 步骤 9 中的图像 2,3 How To Sew With An Awl: 步骤 9 中的图像 3,3
    • Continue reinserting the awl, creating a loop of thread from the eye of the needle, threading the short, free end, and removing the awl to create your stitches.
    • While you are getting the hang of it, refer back to steps 6-9 of this guide.
  10. How To Sew With An Awl: 步骤 10 中的图像 1,3 How To Sew With An Awl: 步骤 10 中的图像 2,3 How To Sew With An Awl: 步骤 10 中的图像 3,3
    • When you come to the end of your material, take one last stitch.
    • Clip the end of the thread that runs through the needle, leaving enough length to tie a couple of knots.
    • Remove the awl.
  11. How To Sew With An Awl: 步骤 11 中的图像 1,2 How To Sew With An Awl: 步骤 11 中的图像 2,2
    • Tie an overhand knot with the two ends of the thread.
    • Pull taught.
    • Tie another knot or two to secure the stitching.
  12. How To Sew With An Awl: 步骤 12 中的图像 1,2 How To Sew With An Awl: 步骤 12 中的图像 2,2
    • Clip the threads, and admire your handiwork.
终点
12等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
88,898 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了16,566篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 112
总计 17,681
