1. In simple world rooting is the process which allows smartphones users to attain root access over various Android subsystems to customized the device operating system.After performing a successful Rooting process user becomes a superuser and has the ability to access system files.SuperSU root is one of the popular rooting methods.
    • In simple world rooting is the process which allows smartphones users to attain root access over various Android subsystems to customized the device operating system.After performing a successful Rooting process user becomes a superuser and has the ability to access system files.SuperSU root is one of the popular rooting methods.
    添加评论
    • SuperSU Root Zip v2.82 is the latest version of the tool and it can be downloaded for free.SuperSU Root Zip file consists of a recovery flashable zip file for SuperSU and the binaries to get root access. You can have your Android device rooted after flashing the SuperSU zip via TWRP custom recovery.
    添加评论
    • Allows advanced management of Superuser access on rooted Android devices
    • Very useful tool for Android developers, gamers and tech teachers
    • Most popular and effective tool for root apps
    • Free of irritating advertisements
    • Compatible with a large number of devices
    • A recognized and well-reputed product in the international security field
    添加评论
  2. 传播 Fixmas 欢乐
    Get $12 off your purchase of $50 or more with code FIXMAS12
    传播 Fixmas 欢乐
    • A Computer (Windows/Mac)
    • TWRP Recovery
    • Latest SuperSU Root zip file v2.82
    • Original USB cable
    • Suggeted Samsung Nougat Device
    添加评论
    • Step 1: Download Latest SuperSU RootZip file v2.82 latest version
    • Step 2: Go to Settings > Software info > Build number > Tap 7-8 times > Enter developer mode
    • Step 3: Turn on USB debugging mode and unlock the phone
    • Step 4: Use the original USB cable and connect the device to the computer and transfer the SuperSU Root zip file into device storage
    • Step 5: Reboot the device into TWRP recovery mode
    • Step 6: Tap on "Install" and "Select" the SuperSU Root 2.82 zip file
    • Step 7 - After selecting the .zip file, do "Swipe to Confirm Flash " and begin the flashing process
    • Step 8: After successful installation of SuperSU Root Zip file, the system will reboot
    添加评论
    • Step 9 - Once you have flashed SuperSU Root, SuperSU APK will be installed. Check for the SuperSU APK in the app drawer
    添加评论
    • Note: If you have already rooted your device using another rooting method you can simply download SuperSU apk from Google Play store and install it as a usual app.
    添加评论
    • Since rooting may cause avoid the software warranty of the device rooting is at your own risk. Do not forget to get a complete back up of your device before the process.
    添加评论
    • All the thanks & credits go to well-known XDA memebr, Chainfire for designing and developing the SuperSu Root and SuperSU APK latest version to root Android devices and manage rooted Androids.
    添加评论
结论
Sally Denton
于2018年11月04日注册
355 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 6
过去的30天: 23
总计 65
