跳转到主内容
How To Replace the Wheels on a Trash Can
你所需要的
  1. How To Replace the Wheels on a Trash Can, Wheels: 步骤 1 中的图像 1,1
    • Flip the trash can upside down.
  2. How To Replace the Wheels on a Trash Can: 步骤 2 中的图像 1,3 How To Replace the Wheels on a Trash Can: 步骤 2 中的图像 2,3 How To Replace the Wheels on a Trash Can: 步骤 2 中的图像 3,3
    • Position the flathead screwdriver on the tab of the pal-nut in the center of the wheel.
    • Position the rubber mallet on top of the flathead screwdriver.
    • Hit the flathead screwdriver with the rubber mallet a couple times for each tab.
    • There are two tabs on each pal-nut, so just do these actions for the pal-nut on one side. The other wheel can remain connected to the axle to remove.
    • This is to push the tab inside to free the pal-nut from the axle that the wheel is connected to.
  3. How To Replace the Wheels on a Trash Can: 步骤 3 中的图像 1,3 How To Replace the Wheels on a Trash Can: 步骤 3 中的图像 2,3 How To Replace the Wheels on a Trash Can: 步骤 3 中的图像 3,3
    • Use the rubber mallet to hit the back of the wheel and loosen the pal-nut.
    • If the pal-nut is stuck, use PB B'LASTER to spray on the pal-nut to break up any rust or corrosion.
    • Caution: Wear gloves so the PB B'LASTER does not get on your skin.
    • Remove the pal-nut.
  4. How To Replace the Wheels on a Trash Can: 步骤 4 中的图像 1,3 How To Replace the Wheels on a Trash Can: 步骤 4 中的图像 2,3 How To Replace the Wheels on a Trash Can: 步骤 4 中的图像 3,3
    • Remove the wheel with the pal-nut from the axle.
    • Slide the other wheel off of the trash can with the axle still attached.
  5. How To Replace the Wheels on a Trash Can: 步骤 5 中的图像 1,3 How To Replace the Wheels on a Trash Can: 步骤 5 中的图像 2,3 How To Replace the Wheels on a Trash Can: 步骤 5 中的图像 3,3
    • To replace with the new parts, reverse the previous steps.
    • Slide the new wheel with the axle on to the trash can.
  6. How To Replace the Wheels on a Trash Can: 步骤 6 中的图像 1,3 How To Replace the Wheels on a Trash Can: 步骤 6 中的图像 2,3 How To Replace the Wheels on a Trash Can: 步骤 6 中的图像 3,3
    • Position the new pal-nut on the axle.
    • Use the rubber mallet and hit the pal-nut on the axle until it is secured.
    • Hold the other side in place while hammering to offer some opposing force. This will help the pal-nut latch on to the axle.
    • Check that both sides are secured.
    • Flip the trash can back to the normal position.
    • Test the new wheels by rolling the trash can.
结论
Now that your trash can is up and rolling again, you can now pat yourself on the back for a job well done!
另外一个人完成了本指南。
Thien Pham
于09/28/20注册
133 声望
撰写一个指南
6指南评论
What size pal nuts on trash barrels
Billcopithorne - 回复
Putting wheels back on trash barrel.Need to replace pal nut and would like to know if there is a standard size to purchase
Billcopithorne - 回复
Hi there!
Upon looking at this specific replacement kit, the Pal-Nut size they used is 5/8”. Since you may have a different trash can with a different size axle, you should refer to any replacement kits made online and see what size Pal-Nut they use.
https://www.homedepot.com/p/Toter-Replac...
Thien Pham -
The nut wont come off. I had to saw the axel in half.
Is Sira - 回复
I am a 65 year grandmother and I replaced the wheels on my 20 year Toter with no issues, Found the repacement parts online. Proud of myself
Rose Wright - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 59
过去 30 天: 189
总计 18,434
