跳转到主内容
How To Replace Ski Pole Baskets
你所需要的
  1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: 步骤 1 中的图像 1,2 How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: 步骤 1 中的图像 2,2
    • Place the sock over your hand like a glove.
    • You will be using this hand to pull off the heated basket.
  2. How To Replace Ski Pole Baskets: 步骤 2 中的图像 1,2 How To Replace Ski Pole Baskets: 步骤 2 中的图像 2,2
    • Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
    • Heat for no longer then three minutes.
  3. How To Replace Ski Pole Baskets: 步骤 3 中的图像 1,2 How To Replace Ski Pole Baskets: 步骤 3 中的图像 2,2
    • Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
  4. How To Replace Ski Pole Baskets: 步骤 4 中的图像 1,2 How To Replace Ski Pole Baskets: 步骤 4 中的图像 2,2
    • Heat an all purpose glue stick with a lighter.
  5. How To Replace Ski Pole Baskets: 步骤 5 中的图像 1,2 How To Replace Ski Pole Baskets: 步骤 5 中的图像 2,2
    • Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
    • Press the new basket immediately after applying the melted glue in order to obtain maximum adhesion.
  6. How To Replace Ski Pole Baskets: 步骤 6 中的图像 1,1
    • Reheat the replaced basket with a hair dryer for a minute.
    • After heating, allow the glue to cool and set for 10 minutes.
  7. How To Replace Ski Pole Baskets: 步骤 7 中的图像 1,1
    • After drying for 10 minutes, your poles will be ready for use. Happy Skiing!
结论
另外一个人完成了本指南。
Lia Garkie
于04/09/15注册
131 声望
撰写一个指南
团队
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 的会员
CPSU-GREEN-S15S30G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 39
总计 17,035
