跳转到主内容
How To Replace Merangue 2-Line Engineering Scientific Calculator Battery
你所需要的
  1. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery, Calculator Battery: 步骤 1 中的图像 1,1
    • Turn the calculator off by holding down the [Shift] button.
    • Then, press the [AC][OFF] button.
    • Always turn your calculator off before removing the battery to prevent potential malfunction.
  2. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 2 中的图像 1,2 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 2 中的图像 2,2
    • Flip the calculator so that the back case is facing you.
    • Use a Phillips #0 screwdriver to remove the single screw from the battery cover at the top of the back case.
    • Keep the screw in a safe place to use when replacing the battery cover later.
    • If the screw does not unfasten easily, do not force it to avoid stripping the screw. If the screw is already stripped refer to the 如何卸下滑丝的螺丝 guide.
  3. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 3 中的图像 1,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 3 中的图像 2,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 3 中的图像 3,3
    • Gently apply pressure to the battery cover and slide it upward.
    • If it doesn't come off easily, try gently wiggling it but do not use excessive force.
  4. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 4 中的图像 1,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 4 中的图像 2,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 4 中的图像 3,3
    • Insert a plastic spudger between the two batteries.
    • Use the plastic spudger to gently pry out the left and right batteries.
    • Do not use metal spudgers, as they can damage to the battery.
    • Do not use force when prying out the batteries to avoid damage.
  5. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 5 中的图像 1,1
    • Put on the nitrile gloves and remove the two batteries from the battery compartment.
    • To dispose of the battery properly consult the How to Recycle End-of-Life Electronics article.
    • Always wear a pair of gloves prior to handling the battery to reduce the risk of chemical burns.
  6. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 6 中的图像 1,1
    • Inspect the battery compartment for any sign of alkaline residue.
    • If the area is clean, skip to step 8.
  7. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 7 中的图像 1,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 7 中的图像 2,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 7 中的图像 3,3
    • Dab a cotton swab in distilled white vinegar.
    • Gently clean the battery compartment in an up and down motion with the cotton swab.
    • Allow the compartment to dry completely for approximately two minutes before inserting the new batteries.
  8. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 8 中的图像 1,1
    • Insert the new LR 1130 batteries in both slots.
    • Make sure the + sign on the battery is facing down in its respective slot.
  9. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 9 中的图像 1,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 9 中的图像 2,3 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 9 中的图像 3,3
    • Slide the battery cover back into place.
    • Use a Phillips #0 screwdriver to secure the battery cover screw.
  10. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: 步骤 10 中的图像 1,1
    • Reset the calculator by pressing the [ON] button.
    • Release the [ON] button and press [Shift].
    • Release the [Shift] button and press the [MODE] button.
    • Release the [MODE] button and press the [3] button to reset all.
    • Release the [3] button and press [=] to confirm the action.
    • Finally, release the [=] button and press the [AC] button to complete the reset.
结论
You have now successfully replaced the battery of a Merangue 2-Line Engineering Scientific Calculator.
3等其他人完成本指南。
Lakshan.14
于07/02/24注册
235 声望
撰写一个指南
团队
York University, Team N-27, O'Regan Summer 2024 York University, Team N-27, O'Regan Summer 2024 的会员
YORK-O'REGAN-SU24SNG27
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 442
