跳转到主内容
How To Replace A Subaru Outback Exhaust Front Cover
你所需要的
  1. How To Replace A  Subaru Outback Exhaust Front Cover, Exhaust Front Cover: 步骤 1 中的图像 1,1
    • Collect Supplies.
    • Make sure the new Exhaust Front Cover is free of stickers, oil, or residues.
  2. How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 2 中的图像 1,1
    • Park Outback on a level dry and clean surface.
    • Make sure that the car is in park for an automatic transmission or in first gear for a manual transmission. Verify that the parking brake is engaged.
  3. How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 3 中的图像 1,1
    • Put on safety glasses. Be sure to leave them on until the fix is complete.
    • Do not touch any exhaust components until you have verified that there is no danger of getting burned.
    • Laying on your back, maneuver yourself underneath the driver or passenger side of the car carrying the 12mm combination wrench. Locate yourself about even with the back of the front door.
  4. How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 4 中的图像 1,3 How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 4 中的图像 2,3 How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 4 中的图像 3,3
    • Unplug the rear oxygen sensor connector and carefully route the wires through the Exhaust Front Cover so they are no longer passing through it.
  5. How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 5 中的图像 1,3 How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 5 中的图像 2,3 How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 5 中的图像 3,3
    • Locate the four mounting bolts for the Exhaust Front Cover.
    • Remove the bolts by turning them counterclockwise using the 12mm combination wrench.
  6. How To Replace A  Subaru Outback Exhaust Front Cover: 步骤 6 中的图像 1,1
    • Remove the old Exhaust Front Cover taking care to prevent damage to the vehicles undercoating and the oxygen sensor wires.
结论
To reassemble your exhaust front cover, follow these instructions in reverse order.
redacted
于02/24/15注册
101 声望
撰写一个指南
团队
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 的会员
CPSU-GREEN-W15S23G1
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,027
