简介
If you notice your Schwinn GTX 3 bike seat keeps slipping, twisting, or falling when you try to ride it then use this guide to fix the clamp that holds the seat in place. You can accomplish this without replacing the clamp and or seat making your bike as good as new again. This is a fairly simple process that shouldn't take more than 10 minutes.
Note: this guide is for the Schwinn GTX 3, this guide might work for other bikes if they use the same clamping mechanism, so check before you start this guide.
你所需要的
Undo the locking mechinisim and remove the seat from the tube.
Loosen the bolt on the clamp to remove it. You should be able to just use hands for this but if the clamp was previously overtightened you can use an Allen wrench to make it easier.
另外一个人完成了本指南。
