简介
Whatever you are a novice or a veteran, if you want to increase the success rate of edge cellphone screen’s refurbishment, do not hesitate to come and see this real stuff.
You know, we usually use two ways to separate edge screens. One is thermal separation, and another is cold separation.
For this time, let’s talk about how to take apart edge screens through thermal separation. As many people like to use Samsung mobile phones and it took the world by storm of its curved screens touch feelings, today we will use Samsung phones an example to discuss thermal separation.
你所需要的
Mid-frame Removing
Put a screen on the heating platform of''' Manual LCD Separator with powerful vacuum'''. Set the heating temperature to 90℃. Heat it in around 30s. Cut an OCA film into strips and drop glue remover liquid X11 into the gap of battery tank. And then scrap the cold glue slowly through the battery tank with a cut strip.
Glass Separating
While separating the glass, the first thing to do is drop on both sides of the glass a glue remover liquid with lubrication and without damaging the LCD (like X11). Then make a little gap at one corner where can entry separation steel wire with a small card. This is to avoid cutting the wrong layer.
Cutting
If you want to separate the glass in advance, you should use a Cutting Machine. Cut off the part of the screen on the top. Use a small manual cutter to cut two small gaps at the top corner of the screen.
Glass Separating
Before the separation, use a blade to drop a little glue remover liquid X11 on both sides of the screen and make a few strokes.
When separating, the angle formed by the steel wire and the long side of the glass should not be bigger than 30 degrees, and separate two sides alternately. The middle part can be separated in parallel, but both sides of the glass must be separated firstly.
Mid-frame Removing
Scrap a gap with a small card on the top corner of the LCD. Please do not take the small card away.
The separation steel wire goes in from under the small card. Separate the mid-frame from the LCD with a separation steel wire. Separate completely where is without flex cables. When encountering the position of a flex cable, using the card to dip a little glue remover liquid X11 and scrap the cold glue slowly.
That’s the methods and skills for separating edge screens through thermal separation. No matter which method you use, you can nail it as long as you are full of patient and confident.
7等其他人完成本指南。
