跳转到主内容
How To Repair An Overheating D-LINK DIR-655 Wireless Router
你所需要的
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 1 中的图像 1,2 How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 1 中的图像 2,2
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 2 中的图像 1,2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 2 中的图像 2,2
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 3 中的图像 1,3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 3 中的图像 2,3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 3 中的图像 3,3
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 4 中的图像 1,1
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 5 中的图像 1,2 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 5 中的图像 2,2
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 6 中的图像 1,1
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 7 中的图像 1,3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 7 中的图像 2,3 How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 7 中的图像 3,3
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 8 中的图像 1,1
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: 步骤 9 中的图像 1,1
    • Wipe away any dust from the the vents to ensure proper airflow.
结论
6等其他人完成本指南。
Chance Daniel
于09/29/15注册
263 声望
撰写一个指南
团队
Cal Poly, Team 10-6, Green Fall 2015 Cal Poly, Team 10-6, Green Fall 2015 的会员
CPSU-GREEN-F15S10G6
3 名成员
创作了3篇指南
一条评论
Fixed my unit :-)
larry_wollen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 5,352
