跳转到主内容
How To Repair A Sticking Mountain Bike Brake Line
你所需要的
  1. How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: 步骤 1 中的图像 1,3 How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: 步骤 1 中的图像 2,3 How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: 步骤 1 中的图像 3,3
    • Remove the grip from the bike's handle bar.
    • Use short twisting motions. If the grip is really stuck onto the bar, some soapy water can help it come off easier.
  2. How To Repair A Sticking Mountain Bike Brake Line: 步骤 2 中的图像 1,2 How To Repair A Sticking Mountain Bike Brake Line: 步骤 2 中的图像 2,2
    • Unscrew the hex screw on the brake fixture on the handle bars with the allen wrench.
    • Once the brake fixture is loose, pull off the fixture form the handle and set aside.
  3. How To Repair A Sticking Mountain Bike Brake Line: 步骤 3 中的图像 1,3 How To Repair A Sticking Mountain Bike Brake Line: 步骤 3 中的图像 2,3 How To Repair A Sticking Mountain Bike Brake Line: 步骤 3 中的图像 3,3
    • Unhook the brake line from the bike's body by sliding the line backwards and pulling up in one motion.
    • If the brake line is too tight to pull back, you may have to remove the rear tire to let the brake pads move farther.
  4. How To Repair A Sticking Mountain Bike Brake Line: 步骤 4 中的图像 1,3 How To Repair A Sticking Mountain Bike Brake Line: 步骤 4 中的图像 2,3 How To Repair A Sticking Mountain Bike Brake Line: 步骤 4 中的图像 3,3
    • Remove the brake line from the brake assembly you removed in step one.
    • Unscrew the adjustment screw all the way out of the assembly.
    • Push brake line forward and slide the line out of the slot in the brake handle.
    • Check the spring of the brake lever without the line connected. If it does not retract well, you can clean it with soapy water.
  5. How To Repair A Sticking Mountain Bike Brake Line: 步骤 5 中的图像 1,2 How To Repair A Sticking Mountain Bike Brake Line: 步骤 5 中的图像 2,2
    • To remove the brake line from the rear brake pads. Unhook the line from the metal insert.
    • Unscrew the hex bolt with an allen wrench.
  6. How To Repair A Sticking Mountain Bike Brake Line: 步骤 6 中的图像 1,1
    • After you have removed the bike's brake line, take the whole assembly wipe with a soapy water solution to remove rust, dirt, grease and anything else stopping the line from traveling freely.
    • After removing all of the debris, apply chain oil to another rag and wipe oil evenly onto the line.
    • Careful the line itself could be frayed anywhere due to age and be sharp.
结论
Once finished, put back together the brake assembly. Then test the mobility of the brakes before riding. Happy Riding!
3等其他人完成本指南。
Spencer Solano
于04/09/15注册
315 声望
撰写一个指南
团队
Cal Poly, Team 30-1, Green Spring 2015 Cal Poly, Team 30-1, Green Spring 2015 的会员
CPSU-GREEN-S15S30G1
4 名成员
创作了7篇指南
一条评论
I’d like to comment just because I think it’s unnecessary to remove the brake leaver as it can be quite a troublesome job to remove and refit the grip and there is really no need to do so in this instance.
ndlz84 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 7,491
