跳转到主内容
How To Repair A Rip In Chiffon Fabric
你所需要的
  1. How To Repair A Rip In Chiffon Fabric, How To Repair A Rip In Chiffon Fabric: 步骤 1 中的图像 1,1
    • Locate the rip in the fabric.
  2. How To Repair A Rip In Chiffon Fabric: 步骤 2 中的图像 1,1
    • Trim off any fraying at the tear.
    • Fold the fabric in half at the tear and cut off the fraying. This makes it easier to clip the smaller frayed fibers as well.
  3. How To Repair A Rip In Chiffon Fabric: 步骤 3 中的图像 1,1
    • Fold the fabric in half at the rip so that the raw edges are right side together.
  4. How To Repair A Rip In Chiffon Fabric: 步骤 4 中的图像 1,1
    • Find a permanent fabric adhesive.
  5. How To Repair A Rip In Chiffon Fabric: 步骤 5 中的图像 1,1
    • Carefully apply the adhesive to the raw edges.
  6. How To Repair A Rip In Chiffon Fabric: 步骤 6 中的图像 1,1
    • Keep the edges together until almost dry.
  7. How To Repair A Rip In Chiffon Fabric: 步骤 7 中的图像 1,1
    • Then lay the cloth flat and push the edges together to make sure the ends stay together.
    • Let the adhesive dry completely.
    • At this point, if your tear/repair is large, you can find a patch that can cover the repair and glue it on.
    • Avoid ironing on the patch. This may cause even more damage to fabric as this material is already very delicate.
结论
Now the damage done to your fabric should be contained and the material should be restored to working order. Hope this helped!
Manasa Dintakurthi
于10/08/20注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 51
过去 30 天: 227
总计 16,321
