简介
This guide will walk you through removing, cleaning, lubricating, and reassembling an older model coaster brake.
你所需要的
Loosen the nuts holding the axle in place using the two wrenches.
Unscrew the brake arm from the frame of the bicycle using the screwdriver.
Congratulations! You've finished cleaning your coaster brake. Test-ride the bicycle. Listen to make sure that there are no grinding noises. Be sure to test the brake several times. When you're done, make sure all the nuts are still tight.
4等其他人完成本指南。
3条评论
I have Huffy coaster bike 26”, i’m trying to change the rear tire bearing but I don’t know the size of it. the outside ones are 3/16 X9, but I need to know the size of the small inner one at the gear it was 7 balls.
Can you explicitly say which order the parts go back in?
It should be easy, but I can't quite get it straight.
