跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Has the string in your hoodie come out in the wash? Do you want to change the string in your hoodie to one of a different color? No matter what your reasoning may be for wanting to restring your hoodie, use this guide to learn how to put a string back in the hood of a sweatshirt.
工具
  1. Uncoil the wire coat hanger into a straight line. Uncoil the wire coat hanger into a straight line.
    • Uncoil the wire coat hanger into a straight line.
  2. Tape the end of the uncoiled coat hanger to one end of your sweatshirt string. Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process. When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. Insert the wire and string apparatus into the left opening of the hoodie.
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Feed the wire through the hoodie until it reaches the top of the hood.
    • Feed the wire through the hoodie until it reaches the top of the hood.
  6. Curve the wire to the right so that the wire can follow the curve of the hood. Curve the wire to the right so that the wire can follow the curve of the hood.
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  7. Continue feeding the wire through the hood towards the other opening of the hoodie. Pull the wire and string out of the opening.
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  8. Remove the tape from the end of the wire and string. Remove the tape from the end of the wire and string.
    • Remove the tape from the end of the wire and string.
  9. Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out. Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  10. Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
结论
Congratulations on restringing your hoodie!
4等其他人完成本指南。
Ashley
于2015年02月24日注册
267 信誉积分
撰写一个指南
团队
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 的会员
CPSU-GREEN-W15S23G1
4 名成员
创作了4篇指南
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 249
