跳转到主内容
How To Re-String A Hoodie
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. How To Re-String A Hoodie, How To Re-String A Hoodie: 步骤 1 中的图像 1,2 How To Re-String A Hoodie, How To Re-String A Hoodie: 步骤 1 中的图像 2,2
    • Uncoil the wire coat hanger into a straight line.
  2. How To Re-String A Hoodie: 步骤 2 中的图像 1,3 How To Re-String A Hoodie: 步骤 2 中的图像 2,3 How To Re-String A Hoodie: 步骤 2 中的图像 3,3
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. How To Re-String A Hoodie: 步骤 3 中的图像 1,1
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. How To Re-String A Hoodie: 步骤 4 中的图像 1,1
    • Feed the wire through the hoodie until it reaches the top of the hood.
  5. How To Re-String A Hoodie: 步骤 5 中的图像 1,2 How To Re-String A Hoodie: 步骤 5 中的图像 2,2
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  6. How To Re-String A Hoodie: 步骤 6 中的图像 1,2 How To Re-String A Hoodie: 步骤 6 中的图像 2,2
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  7. How To Re-String A Hoodie: 步骤 7 中的图像 1,2 How To Re-String A Hoodie: 步骤 7 中的图像 2,2
    • Remove the tape from the end of the wire and string.
  8. How To Re-String A Hoodie: 步骤 8 中的图像 1,2 How To Re-String A Hoodie: 步骤 8 中的图像 2,2
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  9. How To Re-String A Hoodie: 步骤 9 中的图像 1,1
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
结论
Congratulations on restringing your hoodie!
4等其他人完成本指南。
Ashley
于02/24/15注册
267 声望
撰写一个指南
团队
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 的会员
CPSU-GREEN-W15S23G1
4 名成员
创作了4篇指南
一条评论
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 272
