跳转到主内容
How To Patch a Hole in Umbrella Fabric
你所需要的
  1. How To Patch a Hole in Umbrella Fabric, Fabric: 步骤 1 中的图像 1,1
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: 步骤 2 中的图像 1,1
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: 步骤 3 中的图像 1,1
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: 步骤 4 中的图像 1,1
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: 步骤 5 中的图像 1,1
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: 步骤 6 中的图像 1,1
    • Apply your patch squarely over the torn fabric.
结论
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
于10/04/20注册
133 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 79
过去 30 天: 421
总计 12,707
