跳转到主内容
How To Patch A Hole In The Wall
你所需要的
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: 步骤 1 中的图像 1,3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: 步骤 1 中的图像 2,3 How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: 步骤 1 中的图像 3,3
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: 步骤 2 中的图像 1,2 How To Patch A Hole In The Wall: 步骤 2 中的图像 2,2
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: 步骤 3 中的图像 1,1
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: 步骤 4 中的图像 1,3 How To Patch A Hole In The Wall: 步骤 4 中的图像 2,3 How To Patch A Hole In The Wall: 步骤 4 中的图像 3,3
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: 步骤 5 中的图像 1,1
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: 步骤 6 中的图像 1,1
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
结论
Now your wall should be looking as good as new!
3等其他人完成本指南。
Joseph Garcia
于09/29/15注册
293 声望
撰写一个指南
团队
Cal Poly, Team 17-2, Green Fall 2015 Cal Poly, Team 17-2, Green Fall 2015 的会员
CPSU-GREEN-F15S17G2
4 名成员
创作了8篇指南
一条评论
I suggest using a sanding sponge or block in step 6
Dennis - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,472
