跳转到主内容
How To Open A Desktop Hard Drive
你所需要的
  1. How To Open A Desktop Hard Drive, Remove The Front Screws: 步骤 1 中的图像 1,2 How To Open A Desktop Hard Drive, Remove The Front Screws: 步骤 1 中的图像 2,2
    • Use a size 8 Torx screwdriver to remove the front screws. The location and amount may vary depending on your drive, but they are very easy to locate.
  2. How To Open A Desktop Hard Drive, Removing The Hidden Screws: 步骤 2 中的图像 1,2 How To Open A Desktop Hard Drive, Removing The Hidden Screws: 步骤 2 中的图像 2,2
    • There may be a screw hidden under the front sticker, so make sure to peel it off and check before you open it up. Use a spudger to peel off any material in the way of the screw
    • Please check under the sticker before you open up your disk drive. I didn't, and went full brute-force on the hard drive cover. Whoops!
  3. How To Open A Desktop Hard Drive: 步骤 3 中的图像 1,2 How To Open A Desktop Hard Drive: 步骤 3 中的图像 2,2
    • Slide a spudger around the front cover to remove any adhesive or rubber insulation before opening.
  4. How To Open A Desktop Hard Drive: 步骤 4 中的图像 1,1
    • Gently remove the cover.
    • Do NOT do what I did, please.
  5. How To Open A Desktop Hard Drive: 步骤 5 中的图像 1,1
    • There you have it! Now you have a fully-opened hard drive. Whether you want to make a pretty cool (and large) paperweight or perma-delete your data, you can now do so.
结论
This is not a reversible process. I am not responsible for any damage done to you or your hard drive while opening it.
10等其他人完成本指南。
gamer_Kat
于11/11/23注册
391 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 79
总计 1,583
