跳转到主内容
加入维修社区 - 创建账户
How To Maintain The Cooker Hood In Your Appliance
你所需要的
    • Unplug the appliance from any electrical source before starting any maintenance.
    询问修复机器人
    添加评论
    • Detach the grease filter if it is still in place and set it aside.
    • Unscrew or unclip any external panels to expose the interior components.
    • Wear protective gloves to avoid sharp edges and greasy surfaces.
    询问修复机器人
    添加评论
    • Locate and remove screws or clips securing the hood interior and lamp assembly.
    • Lift away plastic or metal covers to gain access to the motor housing.
    • Detach the lamp unit gently if present to protect the bulb and wiring.
    询问修复机器人
    添加评论
    • Remove any electrical components or cable holders from the casing.
    • Set aside circuit boards or switches to keep them dry during cleaning.
    • Keep fasteners and small parts in a secure container for reassembly.
    询问修复机器人
    添加评论
    • Apply a degreasing solution liberally to all hood surfaces and let it soak for approximately 5-6 hours.
    • Use caution around broken or cracked glass components to avoid cuts.
    • Rinse or wipe away any loosened buildup after soaking.
    询问修复机器人
    添加评论
    • Avoid submerging the motor in water to protect windings from damage.
    • Use a suitable solvent with a cloth or brush to remove built-up grease.
    • Disassemble the motor if needed by removing its securing bolts with care.
    • Keep track of clips and photograph their positions for reference.
    询问修复机器人
    添加评论
    • Soak metal panels, fan covers, and removable parts in hot water or a dishwasher.
    • Inspect for sharp edges to prevent injuries during scrubbing and rinsing.
    • Dry all components thoroughly before moving on to reassembly.
    询问修复机器人
    添加评论
    • Lubricate bushings and the motor shaft lightly with appropriate machine oil.
    • Realign the rotor, stator, and washers, ensuring each part is in its original place.
    • Tighten bolts or nuts evenly and check for smooth rotation without friction.
    询问修复机器人
    添加评论
    • Repair or reinforce any cracked lamp housing with suitable materials (duck tape, double-sided tape, aluminum foil).
    • Reattach the motor and all electrical components in reverse order of removal.
    • Reinstall the grease filter and secure all casing panels firmly.
    询问修复机器人
    添加评论
结论
Maintaining your cooker hood keeps it operating at peak performance and extends its service life. Clean, lubricate, and inspect regularly to prevent excessive buildup and electrical issues. With routine care, the hood effectively removes odors and grease, promoting a safer and more pleasant cooking environment.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Ula Gantar
于01/08/25注册
16,609 声望
创作了81篇指南
团队
ZEOS Slovenia ZEOS Slovenia 的会员
Local Repair Groups
2 名成员
创作了164篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 34
过去 30 天: 130
总计 1,774
