跳转到主内容
How To Install a Mac SSD into an External Enclosure
你所需要的
  1. How To Install a Mac SSD into an External Enclosure, Disassemble the enclosure: 步骤 1 中的图像 1,3 How To Install a Mac SSD into an External Enclosure, Disassemble the enclosure: 步骤 1 中的图像 2,3 How To Install a Mac SSD into an External Enclosure, Disassemble the enclosure: 步骤 1 中的图像 3,3
    • Slide the SSD sled out of the metal enclosure to remove it.
  2. How To Install a Mac SSD into an External Enclosure, Install the SSD into the enclosure: 步骤 2 中的图像 1,3 How To Install a Mac SSD into an External Enclosure, Install the SSD into the enclosure: 步骤 2 中的图像 2,3 How To Install a Mac SSD into an External Enclosure, Install the SSD into the enclosure: 步骤 2 中的图像 3,3
    • Carefully insert your Mac OEM SSD as shown, with the golden contact pads below the connector pins facing upward.
    • The SSD and enclosure are both keyed, so the SSD can only be installed one way.
    • The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure.
    • When the SSD is fully inserted, the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
  3. How To Install a Mac SSD into an External Enclosure: 步骤 3 中的图像 1,1
    • Use a Phillips driver to install the 4.5 mm screw securing the bottom of the SSD.
  4. How To Install a Mac SSD into an External Enclosure, Reassemble the enclosure: 步骤 4 中的图像 1,3 How To Install a Mac SSD into an External Enclosure, Reassemble the enclosure: 步骤 4 中的图像 2,3 How To Install a Mac SSD into an External Enclosure, Reassemble the enclosure: 步骤 4 中的图像 3,3
    • Slide the SSD sled into the metal enclosure, SSD connector end first.
    • Make sure the enclosure is in the correct orientation—the sled slides in on the thin rails.
    • The USB-C port should be facing out once installed.
  5. How To Install a Mac SSD into an External Enclosure: 步骤 5 中的图像 1,3 How To Install a Mac SSD into an External Enclosure: 步骤 5 中的图像 2,3 How To Install a Mac SSD into an External Enclosure: 步骤 5 中的图像 3,3
    • Place the port cover plate onto the end of the enclosure, aligning the USB-C port with its cutout.
    • The screw hole chamfers should face outwards.
  6. How To Install a Mac SSD into an External Enclosure: 步骤 6 中的图像 1,1
    • Use a Phillips driver to install the two 8 mm screws onto the end of the enclosure.
  7. How To Install a Mac SSD into an External Enclosure, Use your new external SSD: 步骤 7 中的图像 1,1
    • The drive is now ready to be connected to your computer with either of the included USB cables.
结论
Once your drive is installed, you can transfer data from it, or use Disk Utility to format it and use it as a Time Machine backup.
11等其他人完成本指南。
Carsten Frauenheim
于03/10/20注册
155,682 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,648篇指南
6指南评论
Danke für das Teilen. Es wäre besser, wenn Sie ein zusätzliches Video-Tutorial haben. bloxorz
Halle Promise - 回复
The problem is that unless we're talking about a 2tb or larger SSD, the enclosure for an Apple SSD costs as much or more as just buying an external SSD (as I found out the hard way).
RD6 - 回复
Is there any driver that needs installed for this? My MacBook Pro, a MacBook Air, and a Windows machine do not recognize any USB storage device is being connected at all. Nothing shows up with Disk Utility.
Albert Einstein - 回复
Installed an original MacBook Air 11" Early 2014 SSD drive - doesn't work at all! Waisted €119,95
Raimondas Valuckas - 回复
The install was successful and the drive reads just fine. However, the drive will disconnect itself after a couple minutes. Usually while I'm transferring or browsing files to see which one to transfer next. So basically about the same as all the other generic enclosures I've bought. Is there a fix and or recourse? I don't like wasting over a c-note for something that does the same as the half-priced competitors.
DuchessLadybug - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 135
过去 30 天: 721
总计 49,018
