跳转到主内容
加入维修社区 - 创建账户
How To Install Universal Fit LED Daytime Running Lights
你所需要的
    1. How To Install Universal Fit LED Daytime Running Lights, Philips Style LED Daytime Running Lights Upgrade: 步骤 1 中的图像 1,1
      • Insert the wire into the bracket.
      询问修复机器人
      添加评论
    2. How To Install Universal Fit LED Daytime Running Lights: 步骤 2 中的图像 1,1
      • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
      询问修复机器人
      添加评论
    3. How To Install Universal Fit LED Daytime Running Lights: 步骤 3 中的图像 1,1
      • After mounting the bracket, you can lock the LED daytime running light on the bracket.
      询问修复机器人
      添加评论
    4. How To Install Universal Fit LED Daytime Running Lights: 步骤 4 中的图像 1,2 How To Install Universal Fit LED Daytime Running Lights: 步骤 4 中的图像 2,2
      • Connect the wires and route the wires up and near the fuse box.
      • Use zip ties to tie the wire along the bumper.
      询问修复机器人
      添加评论
    5. How To Install Universal Fit LED Daytime Running Lights: 步骤 5 中的图像 1,2 How To Install Universal Fit LED Daytime Running Lights: 步骤 5 中的图像 2,2
      • Find the ACC in your fuse box and tap the red wire there.
      • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
      • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
      询问修复机器人
      添加评论
    6. How To Install Universal Fit LED Daytime Running Lights: 步骤 6 中的图像 1,1
      • Tap the black wire to battery negative.
      询问修复机器人
      添加评论
    7. How To Install Universal Fit LED Daytime Running Lights: 步骤 7 中的图像 1,3 How To Install Universal Fit LED Daytime Running Lights: 步骤 7 中的图像 2,3 How To Install Universal Fit LED Daytime Running Lights: 步骤 7 中的图像 3,3
      • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
      询问修复机器人
      添加评论
结论
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
取消:我没有完成这个指南。
21等其他人完成本指南。
Eric Wu
于01/21/15注册
3,600 声望
创作了23篇指南
11指南评论
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
http://optixautolabs.com/
Calvin Macaraeg - 回复 分享
Useful info. Thanks
grant.edson - 回复 分享
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
steve finlayson - 回复 分享
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
i cry when i wii - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 32
过去 30 天: 134
总计 96,734
