简介
When moving into an older home, you may find old appliances that may need updating. In this guide, we will be replacing an old universal shower adapter and head for a new universal model.
你所需要的
First, you are going to remove the current shower head from the shower arm.
Twist the shower head counter clock-wise until it is completely removed from arm.
You will now see the existing older model ball adapter, which is not universal for modern shower heads.
Next, you are going to install the new shower arm, which is threaded on both sides to fit modern universal shower heads.
Start by turning the arm clockwise into the threaded pipe in the wall.
After a few turns with your hand, you will need to use a wrench to properly secure the arm into the wall.
Once finished installing the new shower head, turn on the water to make sure there are no leaks. If leaks are found, make sure all seals are tight and there is adequate teflon tape on all threading.
2等其他人完成本指南。
