跳转到主内容
How To Hem Pants With Double-Sided Fabric Tape
你所需要的
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: 步骤 1 中的图像 1,1
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: 步骤 2 中的图像 1,1
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: 步骤 3 中的图像 1,1
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: 步骤 4 中的图像 1,1
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: 步骤 5 中的图像 1,1
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: 步骤 6 中的图像 1,1
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: 步骤 7 中的图像 1,1
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: 步骤 8 中的图像 1,1
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: 步骤 9 中的图像 1,1
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: 步骤 10 中的图像 1,1
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: 步骤 11 中的图像 1,1
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: 步骤 12 中的图像 1,1
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
结论
You don't need a sewing machine to hem a pair of overly long pants.
另外一个人完成了本指南。
Allison
于10/07/23注册
232 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 74
总计 983
