跳转到主内容
How To Fix a Hole in the Sole of a Adidas Gazelles Shoe
你所需要的
  1. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe, How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 1 中的图像 1,1
    • To begin, clean the Adidas Gazelles with some water on a towel.
    • Be careful not to use too much water or you could further damage your shoes.
  2. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 2 中的图像 1,2 How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 2 中的图像 2,2
    • Carefully use the utility knife to free the hole of any excess material.
    • Make sure and clear the Gazelles of any debris that could be stuck under the loose squares of the sole.
  3. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 3 中的图像 1,1
    • Use 100 grit sandpaper to roughen the inside surface of the hole.
    • This will help the shoe goo grip the surface of the shoe, and produce a more lasting fix.
  4. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 4 中的图像 1,2 How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 4 中的图像 2,2
    • Apply shoe goo to the inside of the hole in the sole of your Adidas Gazelles.
    • Make sure to apply evenly to avoid making your Gazelles off balance.
    • If there is anywhere else on your Gazelle's sole that could use additional protection, apply shoe goo to those surfaces as well.
  5. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 5 中的图像 1,1
    • Take your putty knife and smooth the shoe goo flush to the surface of the sole.
    • Try to spread the shoe goo in one direction to increase surface smoothness.
  6. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 6 中的图像 1,1
    • Now place your Gazelles in a safe and clean place to dry for 24 hours.
  7. How To Fix a Hole in the Sole of a Adidas Gazelles Shoe: 步骤 7 中的图像 1,1
    • After 24 hours, use 150 grit sandpaper to rub down the surface of your filled hole to create a smooth surface.
结论
Now with the hole repaired your Gazelles are ready for action. With the proper care you can extend their life for many years to come.
11等其他人完成本指南。
Hayden
于04/09/15注册
533 声望
撰写一个指南
团队
Cal Poly, Team 28-3, Green Spring 2015 Cal Poly, Team 28-3, Green Spring 2015 的会员
CPSU-GREEN-S15S28G3
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 85
过去 30 天: 190
总计 23,554
