跳转到主内容
How To Fix a Broken Bra Hook
你所需要的
  1. How To Fix a Broken Bra Hook, How To Fix a Broken Bra Hook: 步骤 1 中的图像 1,3 How To Fix a Broken Bra Hook, How To Fix a Broken Bra Hook: 步骤 1 中的图像 2,3 How To Fix a Broken Bra Hook, How To Fix a Broken Bra Hook: 步骤 1 中的图像 3,3
    • Use a seam ripper to rip off the seams on either side of the broken hook and also the edge seam.
    • Make sure to not rip off the seam of other hooks.
    • Point the head of the seam ripper away from you to prevent poking yourself
  2. How To Fix a Broken Bra Hook: 步骤 2 中的图像 1,3 How To Fix a Broken Bra Hook: 步骤 2 中的图像 2,3 How To Fix a Broken Bra Hook: 步骤 2 中的图像 3,3
    • Remove the broken hook from the strap.
    • Pull or cut off the threads that are still attached to the strap.
  3. How To Fix a Broken Bra Hook: 步骤 3 中的图像 1,1
    • Insert the new hook into the strap.
    • Use fingers to hold the hook in the strap.
  4. How To Fix a Broken Bra Hook: 步骤 4 中的图像 1,3 How To Fix a Broken Bra Hook: 步骤 4 中的图像 2,3 How To Fix a Broken Bra Hook: 步骤 4 中的图像 3,3
    • Place the tip of the pin next to the new hook.
    • Make sure the pin is placed in the middle of the hook.
    • Push the pin until it goes through the strap and reach for back of the pin.
    • Point the tip of the pin next to the other side of the hook.
    • Push pin again to make it go through to the front of the strap.
    • Push the pin slowly to avoid poking yourself!
  5. How To Fix a Broken Bra Hook: 步骤 5 中的图像 1,1
    • Put the hooks into the eyes of the bra to make sure hook is placed correctly.
  6. How To Fix a Broken Bra Hook: 步骤 6 中的图像 1,2 How To Fix a Broken Bra Hook: 步骤 6 中的图像 2,2
    • Thread needle with thread the same color as the bra.
    • Pull the thread through to an appropriate length.
    • Approx. 10-12 inches.
    • Cut the thread.
  7. How To Fix a Broken Bra Hook: 步骤 7 中的图像 1,1
    • Tie the thread into a knot at the end of the thread.
    • Tie two or three times for a thicker knot.
  8. How To Fix a Broken Bra Hook: 步骤 8 中的图像 1,1
    • Cut the excess thread off with the scissors.
    • Do as close as possible to the knot for a clean seam.
  9. How To Fix a Broken Bra Hook: 步骤 9 中的图像 1,2 How To Fix a Broken Bra Hook: 步骤 9 中的图像 2,2
    • Feel around for one of the two holes at the bottom of the new hook.
    • This will not be visible and may take some time to locate.
    • Stick the threaded needle through the hole of the hook.
    • Use a backstitch to sew the hook into place.
    • Repeat this for the other hole in the same hook.
    • Always watch out for the tip of the needle while sewing!
  10. How To Fix a Broken Bra Hook: 步骤 10 中的图像 1,2 How To Fix a Broken Bra Hook: 步骤 10 中的图像 2,2
    • Make a large loop with the thread when finished sewing the hook into place.
    • Place your finger on the point where you would like the knot to be and pull on the thread.
    • Knot two or three times.
  11. How To Fix a Broken Bra Hook: 步骤 11 中的图像 1,2 How To Fix a Broken Bra Hook: 步骤 11 中的图像 2,2
    • Cut excess thread off with the scissors.
    • Do this as close as possible to the knot for no loose threads.
  12. How To Fix a Broken Bra Hook: 步骤 12 中的图像 1,1
    • Remove the pin carefully.
  13. How To Fix a Broken Bra Hook: 步骤 13 中的图像 1,1
    • Tie a knot at the end of the thread.
  14. How To Fix a Broken Bra Hook: 步骤 14 中的图像 1,2 How To Fix a Broken Bra Hook: 步骤 14 中的图像 2,2
    • Hand stitch the edge using a backstitch to close the seam.
    • Pay attention to the tip of the needle to avoid poking your fingers!
  15. How To Fix a Broken Bra Hook: 步骤 15 中的图像 1,3 How To Fix a Broken Bra Hook: 步骤 15 中的图像 2,3 How To Fix a Broken Bra Hook: 步骤 15 中的图像 3,3
    • Tie a knot at the end when you finish closing the seam.
    • Hold finger down on the thread to make sure the knot is as close to the bra as possible.
  16. How To Fix a Broken Bra Hook: 步骤 16 中的图像 1,1
    • Cut extra thread with the scissors.
  17. How To Fix a Broken Bra Hook: 步骤 17 中的图像 1,2 How To Fix a Broken Bra Hook: 步骤 17 中的图像 2,2
    • Try hook and eye to see if it fits appropriately.
结论
Tada! You saved your bra from an early grave in the dump!
8等其他人完成本指南。
Hang
于10/26/18注册
380 声望
撰写一个指南
团队
UC Davis, Team S1-G7, Bender Fall 2018 UC Davis, Team S1-G7, Bender Fall 2018 的会员
UCD-BENDER-F18S1G7
3 名成员
创作了1篇指南
8条评论
What size hook do I need?
joellewalters - 回复
Thank you . you took it from being overwhelming to …. Its fixed. Yippeee thank
Tracey Banish - 回复
Your instructions were super clear — It works!!! Thank you!
Michele King - 回复
beautiful instructions. thank you for clear pictures too. i knew it was possible but it was nice to see a step by step.
inspiredtosew - 回复
same never answered question: I need to buy new hooks: they seem to come in size 0-3.. what do I need???
nej - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 116
过去 30 天: 635
总计 32,300
