跳转到主内容
How To Fix Torn Winter Earmuffs
你所需要的
  1. How To Fix Torn Winter Earmuffs, How To Fix Torn Winter Earmuffs: 步骤 1 中的图像 1,1
    • Cut approximately 30 cm of thread with scissors.
    • The thread length will vary depending on the size of the area that needs to be sewn.
  2. How To Fix Torn Winter Earmuffs: 步骤 2 中的图像 1,1
    • Insert the sewing thread through the eye of the needle.
    • Keep your fingers away from the sharp tip of the needle to avoid injury. If necessary, use a thimble to protect your finger.
    • If you have trouble getting the thread through the eye of the needle, you can lick the tip of the thread. This will tighten the thread fibers and allow easier insertion into the needle.
  3. How To Fix Torn Winter Earmuffs: 步骤 3 中的图像 1,1
    • Pull the thread through the eye of the needle until equal amounts of thread are on each side.
    • This is called a double thread, and it makes the thread stronger. It is not required, but it is helpful.
  4. How To Fix Torn Winter Earmuffs: 步骤 4 中的图像 1,2 How To Fix Torn Winter Earmuffs: 步骤 4 中的图像 2,2
    • Tie a solid knot around the needle to secure the thread, repeating if necessary.
  5. How To Fix Torn Winter Earmuffs: 步骤 5 中的图像 1,2 How To Fix Torn Winter Earmuffs: 步骤 5 中的图像 2,2
    • Using an invisible seam stitch, sew the earmuff onto the headband.
    • For easier visibility, these images show a thread color that contrasts with the earmuffs. Be sure to choose a thread color that matches with your earmuffs.
  6. How To Fix Torn Winter Earmuffs: 步骤 6 中的图像 1,3 How To Fix Torn Winter Earmuffs: 步骤 6 中的图像 2,3 How To Fix Torn Winter Earmuffs: 步骤 6 中的图像 3,3
    • Pull the thread tight and tie a solid knot to secure it on the earmuff.
  7. How To Fix Torn Winter Earmuffs: 步骤 7 中的图像 1,3 How To Fix Torn Winter Earmuffs: 步骤 7 中的图像 2,3 How To Fix Torn Winter Earmuffs: 步骤 7 中的图像 3,3
    • Near the knot, insert the needle and thread into the earmuffs.
    • Pull the needle and thread out of the earmuffs towards yourself.
  8. How To Fix Torn Winter Earmuffs: 步骤 8 中的图像 1,2 How To Fix Torn Winter Earmuffs: 步骤 8 中的图像 2,2
    • Trim the excess thread.
  9. How To Fix Torn Winter Earmuffs: 步骤 9 中的图像 1,2 How To Fix Torn Winter Earmuffs: 步骤 9 中的图像 2,2
    • Locate any additional excess thread.
    • Pull the earmuff fabric gently to tuck the thread inside.
结论
You have now fixed your winter earmuffs. Congratulations!
2等其他人完成本指南。
Violet Ichel
于11/04/24注册
187 声望
撰写一个指南
团队
UC Davis, Team 3-6, Vidal-Chiesa Fall 2024 UC Davis, Team 3-6, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S3G6
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 97
总计 392
