跳转到主内容
加入维修社区 - 创建账户
How To Fix Misaligned Bicycle Handlebars
你所需要的
  1. How To Fix Misaligned Bicycle Handlebars, How To Fix Misaligned Bicycle Handlebars: 步骤 1 中的图像 1,2 How To Fix Misaligned Bicycle Handlebars, How To Fix Misaligned Bicycle Handlebars: 步骤 1 中的图像 2,2
    • Stand with your bicycle in front of you.
    • Put your front wheel between your legs.
  2. How To Fix Misaligned Bicycle Handlebars: 步骤 2 中的图像 1,1
    • Hold the bike's front wheel tight with your legs to keep the bike upright.
    • Grab the handlebar and make it perpendicular to the front wheel.
    • Keep your bike stable at all times.
  3. How To Fix Misaligned Bicycle Handlebars: 步骤 3 中的图像 1,3 How To Fix Misaligned Bicycle Handlebars: 步骤 3 中的图像 2,3 How To Fix Misaligned Bicycle Handlebars: 步骤 3 中的图像 3,3
    • Loosen the stem using the Allen wrench. Do minor adjustments using your hand.
    • Put the handlebar in a straight position. Then use a ruler, tape measure, or adjust by sight to the correct placement.
  4. How To Fix Misaligned Bicycle Handlebars: 步骤 4 中的图像 1,2 How To Fix Misaligned Bicycle Handlebars: 步骤 4 中的图像 2,2
    • DO NOT move your handle bars when you are adjusting the position.
    • Use the Allen wrench or Hex key to gently turn the two bolts (some bikes have one) on the stem until they hold tight.
  5. How To Fix Misaligned Bicycle Handlebars: 步骤 5 中的图像 1,1
    • After tightening the bolt(s), check the alignment again.
    • Now, try rotating your bike using handlebar.
    • If it's still loose that means you may need to replace the handlebar.
  6. How To Fix Misaligned Bicycle Handlebars: 步骤 6 中的图像 1,1
    • If your handlebar works as expected you can ride your bike now.
    • Have a safe trip!
结论
Using this guide will help you easily fix your handlebar.
附加文件
Telmuun
于09/07/21注册
133 声望
撰写一个指南
团队
York University, Team 1-26, O'Regan Fall 2021 York University, Team 1-26, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21S1G26
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 89
总计 17,723
