你所需要的
remove the three Phillips screws under the fan closest to the video ports of the card
Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
即将完成!
结论
8等其他人完成本指南。
