跳转到主内容
How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
你所需要的
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: 步骤 1 中的图像 1,1
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: 步骤 2 中的图像 1,1
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: 步骤 3 中的图像 1,1
    • Reassemble and re-install the card into your computer. It should stop the vibration.
结论
8等其他人完成本指南。
一条评论
Can you post a picture showing how its fit in the fins?
Gustavo Horta - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 8,308
