跳转到主内容
How To Fix A Hole In Khaki Pants
你所需要的
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: 步骤 1 中的图像 1,1
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: 步骤 2 中的图像 1,1
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: 步骤 3 中的图像 1,1
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: 步骤 4 中的图像 1,1
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: 步骤 5 中的图像 1,2 How To Fix A Hole In Khaki Pants: 步骤 5 中的图像 2,2
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: 步骤 6 中的图像 1,2 How To Fix A Hole In Khaki Pants: 步骤 6 中的图像 2,2
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: 步骤 7 中的图像 1,1
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: 步骤 8 中的图像 1,1
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: 步骤 9 中的图像 1,1
    • Now put your khaki pants on because they are now wearable again and practically new!
结论
Now your old ripped pants look practically new and you can begin wearing them again.
6等其他人完成本指南。
Calvin Roth
于09/27/15注册
291 声望
撰写一个指南
团队
Cal Poly, Team 17-1, Green Fall 2015 Cal Poly, Team 17-1, Green Fall 2015 的会员
CPSU-GREEN-F15S17G1
4 名成员
创作了5篇指南
5条评论
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - 回复
and 100% maching
Shafikahmed - 回复
Iam shafik i can't do it's and 100% maching
Shafikahmed - 回复
What about if you’re in school and your pants rip?
EMMA MILLER - 回复
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 143
总计 51,465
