跳转到主内容
How To Fix A Frayed Buttonhole
你所需要的
  1. How To Fix A Frayed Buttonhole, How To Fix A Frayed Buttonhole: 步骤 1 中的图像 1,3 How To Fix A Frayed Buttonhole, How To Fix A Frayed Buttonhole: 步骤 1 中的图像 2,3 How To Fix A Frayed Buttonhole, How To Fix A Frayed Buttonhole: 步骤 1 中的图像 3,3
    • With a seam ripper, carefully remove all the threads from the frayed buttonhole.
  2. How To Fix A Frayed Buttonhole: 步骤 2 中的图像 1,1
    • Find a thread that closely matches the thread on the pants.
  3. How To Fix A Frayed Buttonhole: 步骤 3 中的图像 1,3 How To Fix A Frayed Buttonhole: 步骤 3 中的图像 2,3 How To Fix A Frayed Buttonhole: 步骤 3 中的图像 3,3
    • Holding the fabric right-side up with the buttonhole horizontal, begin stitching at the edge.
    • Start from the inner side.
    • Be cautious of your hand placement when pushing the needle through the fabric.
  4. How To Fix A Frayed Buttonhole: 步骤 4 中的图像 1,3 How To Fix A Frayed Buttonhole: 步骤 4 中的图像 2,3 How To Fix A Frayed Buttonhole: 步骤 4 中的图像 3,3
    • The needle should be on the front side.
    • Put the needle in between the layers of fabric and pull it through towards the inner side, securing the fabrics together.
  5. How To Fix A Frayed Buttonhole: 步骤 5 中的图像 1,3 How To Fix A Frayed Buttonhole: 步骤 5 中的图像 2,3 How To Fix A Frayed Buttonhole: 步骤 5 中的图像 3,3
    • The needle is on the inner side.
    • Pull the needle through the buttonhole towards the other side.
    • Do not put the needle through the fabric.
  6. How To Fix A Frayed Buttonhole: 步骤 6 中的图像 1,2 How To Fix A Frayed Buttonhole: 步骤 6 中的图像 2,2
    • Continue making buttonhole stitches along the side of the buttonhole.
    • Keep the stitches close together.
  7. How To Fix A Frayed Buttonhole: 步骤 7 中的图像 1,3 How To Fix A Frayed Buttonhole: 步骤 7 中的图像 2,3 How To Fix A Frayed Buttonhole: 步骤 7 中的图像 3,3
    • On the back side, tie a knot to seal the thread.
  8. How To Fix A Frayed Buttonhole: 步骤 8 中的图像 1,2 How To Fix A Frayed Buttonhole: 步骤 8 中的图像 2,2
    • After sealing the knot, the button should fit into the buttonhole.
结论
This guide should be easy to anybody with sewing experience, and if you don’t have sewing experience, then this guide should be a good beginners guide on how to get familiar with sewing.
4等其他人完成本指南。
Adina Asif
于01/21/21注册
238 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 105
总计 10,147
