跳转到主内容
How To Fix A Broken Makeup Brush
你所需要的
  1. How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: 步骤 1 中的图像 1,2 How To Fix A Broken Makeup Brush, How To Fix A Broken Makeup Brush: 步骤 1 中的图像 2,2
    • Remove excess glue on the handle and the base of the brush using a nail file.
  2. How To Fix A Broken Makeup Brush: 步骤 2 中的图像 1,1
    • Use the hot glue gun to apply glue to the inside base of the brush where the handle is attached.
    • Be cautious of the high temperature of the glue and gun when handling.
  3. How To Fix A Broken Makeup Brush: 步骤 3 中的图像 1,1
    • Slowly place the brush head onto the handle and apply pressure for 15 seconds.
  4. How To Fix A Broken Makeup Brush: 步骤 4 中的图像 1,1
    • Remove excess glue from the brush using a paper towel.
  5. How To Fix A Broken Makeup Brush: 步骤 5 中的图像 1,1
    • Let the glue dry for 2-3 minutes to be sure it is securely attached.
终点
Shanae Swack
于02/23/16注册
403 声望
撰写一个指南
团队
Texas Tech, Team 26-4, Rauch Spring 2016 Texas Tech, Team 26-4, Rauch Spring 2016 的会员
TTU-RAUCH-S16S26G4
3 名成员
创作了1篇指南
一条评论
Amazing!!! Thanks a lot.
Amal - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 6,013
