跳转到主内容
加入维修社区 - 创建账户
How To Do An Oil Change With An Oil Extractor/Pump
你所需要的
视频概述
    1. How To Do An Oil Change With An Oil Extractor/Pump, Oil and Oil Filter: 步骤 1 中的图像 1,3 How To Do An Oil Change With An Oil Extractor/Pump, Oil and Oil Filter: 步骤 1 中的图像 2,3 How To Do An Oil Change With An Oil Extractor/Pump, Oil and Oil Filter: 步骤 1 中的图像 3,3
      • Open the engine bay and locate the oil filter, oil fill hole, and dipstick/oil suction hole.
      • Remove the engine cover if necessary.
      询问修复机器人
      添加评论
    2. How To Do An Oil Change With An Oil Extractor/Pump: 步骤 2 中的图像 1,2 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 2 中的图像 2,2
      • Remove the oil suction plug or dipstick.
      • Break loose the filter or filter cap.
      询问修复机器人
      添加评论
    3. How To Do An Oil Change With An Oil Extractor/Pump: 步骤 3 中的图像 1,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 3 中的图像 2,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 3 中的图像 3,3
      • Insert the pump tube into the fill hole/dipstick hole. Continue to feed until the tube hits the bottom.
      • Attach positive and negative alligator clips onto the battery terminal
      • This is not necessary if you’re using a manual pump.
      • Start the suction motor by flipping the "On" switch and start collecting the used oil into a container.
      • For manual pumps, start pumping.
      • The referenced vehicle has a trunk mounted battery. There is also an extended positive terminal to the front (circled in orange on the right side of photo 2 of step 3) If no negative terminal is available, secure the ground clip to exposed metal on the vehicle frame or engine block.
      询问修复机器人
      添加评论
    4. How To Do An Oil Change With An Oil Extractor/Pump: 步骤 4 中的图像 1,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 4 中的图像 2,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 4 中的图像 3,3
      • Break the oil filter loose with a ratchet or filter wrench.
      • If the filter has a housing, remove the filter assembly and replace the filter inside.
      • Replace the O-ring. (A screwdriver may make this process easier.) Make sure the O-ring goes back into the same slot as before and lubricate it with some oil.
      • If your oil filter does not reuse the housing, skip these steps and go straight to lubricating the O ring on the new filter.
      • Brake clean can be used to clean the inside of the housing but it is not necessary.
      询问修复机器人
      添加评论
    5. How To Do An Oil Change With An Oil Extractor/Pump: 步骤 5 中的图像 1,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 5 中的图像 2,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 5 中的图像 3,3
      • After lubrication, hand tighten the filter into the slot.
      • Using a torque wrench, torque the filter to manufacturer's specification
      • For the vehicle referenced, torque specification is 25-foot pounds (about 32 newton meters).
      询问修复机器人
      添加评论
    6. How To Do An Oil Change With An Oil Extractor/Pump: 步骤 6 中的图像 1,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 6 中的图像 2,3 How To Do An Oil Change With An Oil Extractor/Pump: 步骤 6 中的图像 3,3
      • Unscrew the oil filler cap and add oil to manufacturer’s specification. Oil capacity can usually be found in vehicle user manuals. If necessary, use a funnel to limit splash.
      • Use the dipstick to check the oil level. Make sure the car is on a level surface.
      询问修复机器人
      添加评论
结论
Let vehicle idle up to operating temperatures, check for leaks, and ensure there are no anomalies before taking your first test drive
取消:我没有完成这个指南。
5等其他人完成本指南。
附加文件
Ryan Wu
于09/17/21注册
255 声望
撰写一个指南
团队
York University, Team E-29, Melo-Thaiss Fall 2021 York University, Team E-29, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG29
1 名成员
创作了9篇指南
1指南评论
For cars with no dip stick, can the suction tube be sent down the hole of the oil cartridge once the filter is removed? Or down the filler cap?
Vinsk - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 54
过去 30 天: 218
总计 12,139
