跳转到主内容
加入维修社区 - 创建账户
Hoverboard Bluetooth Remote Control Replacement
你所需要的
  1. Hoverboard Bluetooth Remote Control Replacement, Bluetooth Remote Control: 步骤 1 中的图像 1,1
    • Remove the 10 screws with a Phillips screwdriver to access the inside of the hoverboard.
    • The electronic circuit boards are mirrored on both sides, so examine them both to determine which has the Bluetooth setup.
    询问修复机器人
  2. Hoverboard Bluetooth Remote Control Replacement: 步骤 2 中的图像 1,1
    • Unhook the lighting and indicator light wires to remove the cover.
    询问修复机器人
  3. Hoverboard Bluetooth Remote Control Replacement: 步骤 3 中的图像 1,1
    • Remove the 4 screws that hold the circuit board support.
    询问修复机器人
  4. Hoverboard Bluetooth Remote Control Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 screws that secure the board to the support.
    询问修复机器人
  5. Hoverboard Bluetooth Remote Control Replacement: 步骤 5 中的图像 1,1
    • Remember the sequence of wires to be soldered on the Bluetooth board.
    询问修复机器人
  6. Hoverboard Bluetooth Remote Control Replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to affix the 4 pins of the Bluetooth board onto the hoverboard board
    • Before soldering the boards, check the functionality of the Bluetooth board by merely inserting the pins, which is enough.
    询问修复机器人
结论
To reassemble your device, Follow these instructions in reverse order.
另外一个人完成了本指南。
由衷感谢以下译者:
it en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Smilzo
于11/09/13注册
12,320 声望
创作了39篇指南
4指南评论
Hello! Would it be possible to know where to get that bluetooth module? I would like to try that one my hoverboard but cant find the needed part.
Nix Mathy - 回复 分享
Ciao,puoi cercare su EBay AliExpress Wish ed altri store cinesi
Smilzo - 回复 分享
Well after 5 days of search on ali.. ebay.. bangood.. amazon. I still haven't found the good part.
I've ask a lots of sellers and they all replied the module they sell is only for music no app control :(
Nix Mathy - 回复 分享
Nix Mathy devi cercare bene come parola chiave.io li vedo su tanti store
telecomando self balance hoverboard
https://www.amazon.it/Hoverboard-Telecom...
https://www.ebay.it/itm/REPLACEMENT-REMO...
Smilzo - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 88
总计 2,162
