跳转到主内容
加入维修社区 - 创建账户
Hover-1 XLS Ignition Replacement
你所需要的
  1. Hover-1 XLS Ignition Replacement, Ignition: 步骤 1 中的图像 1,1
    • Remove the six 16mm #3 Hex head screws located on the front panel.
    • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
  2. Hover-1 XLS Ignition Replacement: 步骤 2 中的图像 1,3 Hover-1 XLS Ignition Replacement: 步骤 2 中的图像 2,3 Hover-1 XLS Ignition Replacement: 步骤 2 中的图像 3,3
    • Grab the front panel and gently lift it up to the side.
    • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
  3. Hover-1 XLS Ignition Replacement: 步骤 3 中的图像 1,1
    • Remove the two, 19 mm Phillips #2 screws holding the ignition.
    • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
结论
团队
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 的会员
CPSU-WHITE-W19S1G2
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 46
总计 1,457
