跳转到主内容
Hover-1 XLS Front Wheel Replacement
你所需要的
  1. Hover-1 XLS Front Wheel Replacement, Front Brake: 步骤 1 中的图像 1,3 Hover-1 XLS Front Wheel Replacement, Front Brake: 步骤 1 中的图像 2,3 Hover-1 XLS Front Wheel Replacement, Front Brake: 步骤 1 中的图像 3,3
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Front Wheel Replacement: 步骤 2 中的图像 1,1
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Front Wheel Replacement: 步骤 3 中的图像 1,2 Hover-1 XLS Front Wheel Replacement: 步骤 3 中的图像 2,2
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
  4. Hover-1 XLS Front Wheel Replacement, Front Wheel: 步骤 4 中的图像 1,2 Hover-1 XLS Front Wheel Replacement, Front Wheel: 步骤 4 中的图像 2,2
    • Remove the two, 16 mm Hex #4 screws on both of the hub caps in the front wheel.
    • There are two hub caps on the front wheel. Make sure to remove two screws for both hub caps.
  5. Hover-1 XLS Front Wheel Replacement: 步骤 5 中的图像 1,2 Hover-1 XLS Front Wheel Replacement: 步骤 5 中的图像 2,2
    • Using an adjustable spanner wrench, rotate the 165 mm bolt counter-clockwise to remove.
  6. Hover-1 XLS Front Wheel Replacement: 步骤 6 中的图像 1,3 Hover-1 XLS Front Wheel Replacement: 步骤 6 中的图像 2,3 Hover-1 XLS Front Wheel Replacement: 步骤 6 中的图像 3,3
    • After removing the first bolt, the second bolt located on the other side of the wheel will be able to be take off by hand.
    • Pull the wheel and bike in opposite directions to remove the wheel.
结论
2等其他人完成本指南。
Jonathan Hidalgo
于01/24/19注册
596 声望
创作了5篇指南
团队
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 的会员
CPSU-WHITE-W19S1G2
3 名成员
创作了6篇指南
一条评论
How do I get in touch with customer service for parts?
tried filling out the form on computer and phone as well tablet and it says error.
fox_Jayson@yahoo.com
please reach out
petrasherbin - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 24
总计 1,252
