跳转到主内容
加入维修社区 - 创建账户
Hover-1 XLS Battery Replacement
你所需要的
  1. Hover-1 XLS Battery Replacement, Battery: 步骤 1 中的图像 1,3 Hover-1 XLS Battery Replacement, Battery: 步骤 1 中的图像 2,3 Hover-1 XLS Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
    • There are four screws that need to remove. Two on one side and the two on the opposite side.
  2. Hover-1 XLS Battery Replacement: 步骤 2 中的图像 1,3 Hover-1 XLS Battery Replacement: 步骤 2 中的图像 2,3 Hover-1 XLS Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the adhesive holding the wires tightly.
    • You can use a sharp object to score the adhesive before pulling.
    • Pull on both sides of the wire connections.
结论
3等其他人完成本指南。
团队
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 的会员
CPSU-WHITE-W19S1G2
3 名成员
创作了7篇指南
17指南评论
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - 回复 分享
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - 分享
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - 回复 分享
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - 分享
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 46
过去 30 天: 212
总计 13,494
