跳转到主内容
简介
Is your Hover-1 Ultra not charging to full battery, or not powering up at all? If you are experiencing these problems, it can be fixed with a very simple replacement of the charging port of your device. You will need a Phillips #1 screwdriver to remove the screws and an adjustable crescent wrench to remove the port
配件
没有特定配件。
  1. Orient the hoverboard so that the pads are facing down. With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board. Carefully remove the shell, lifting directly up.
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Using your hands or a crescent wrench, begin removing the charging port. Turn the charging port counter-clockwise to release it from the shell.
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  4. Unclip the insulated red and black wires  attached to the port from the motherboard Unclip the insulated red and black wires  attached to the port from the motherboard Unclip the insulated red and black wires  attached to the port from the motherboard
    • Unclip the insulated red and black wires attached to the port from the motherboard
  5. Remove the charging port through the assembly. Place new charging port through the assembly. Clip red and black insulated wires into the motherboard.
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
结论
To reassemble your device, follow the instructions for step 1 in reverse order.
另外一个人完成了本指南。
Camron Clifton
于2018年10月22日注册
331 信誉积分
创作了3篇指南
团队
UC Davis, Team S7-G5, Lore Fall 2018 UC Davis, Team S7-G5, Lore Fall 2018 的会员
UCD-LORE-F18S7G5
3 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 11
总计 102
