跳转到主内容
Hover-1 Titan Wheel and Motor Replacement
你所需要的
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: 步骤 1 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: 步骤 1 中的图像 2,2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: 步骤 2 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: 步骤 3 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 3 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 3 中的图像 3,3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: 步骤 4 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: 步骤 4 中的图像 2,2
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: 步骤 5 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: 步骤 6 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 6 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 6 中的图像 3,3
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: 步骤 7 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 7 中的图像 2,2
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: 步骤 8 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 8 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 8 中的图像 3,3
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: 步骤 9 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 9 中的图像 2,2
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: 步骤 10 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 10 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 10 中的图像 3,3
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: 步骤 11 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 11 中的图像 2,2
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: 步骤 12 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 12 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 12 中的图像 3,3
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: 步骤 13 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 13 中的图像 2,2
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: 步骤 14 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 14 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 14 中的图像 3,3
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: 步骤 15 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 15 中的图像 2,2
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: 步骤 16 中的图像 1,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 16 中的图像 2,3 Hover-1 Titan Wheel and Motor Replacement: 步骤 16 中的图像 3,3
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: 步骤 17 中的图像 1,2 Hover-1 Titan Wheel and Motor Replacement: 步骤 17 中的图像 2,2
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
结论
3等其他人完成本指南。
Emma Huun
于10/08/18注册
312 声望
撰写一个指南
团队
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 的会员
CPSU-WHITE-F18S15G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 17
过去 30 天: 46
总计 1,671
