跳转到主内容
Hover-1 Titan Right Gyroscope Replacement
你所需要的
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: 步骤 1 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: 步骤 1 中的图像 2,2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: 步骤 2 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: 步骤 3 中的图像 1,3 Hover-1 Titan Right Gyroscope Replacement: 步骤 3 中的图像 2,3 Hover-1 Titan Right Gyroscope Replacement: 步骤 3 中的图像 3,3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: 步骤 4 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: 步骤 4 中的图像 2,2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: 步骤 5 中的图像 1,3 Hover-1 Titan Right Gyroscope Replacement: 步骤 5 中的图像 2,3 Hover-1 Titan Right Gyroscope Replacement: 步骤 5 中的图像 3,3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: 步骤 6 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement: 步骤 6 中的图像 2,2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: 步骤 7 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement: 步骤 7 中的图像 2,2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: 步骤 8 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement: 步骤 8 中的图像 2,2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: 步骤 9 中的图像 1,2 Hover-1 Titan Right Gyroscope Replacement: 步骤 9 中的图像 2,2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: 步骤 10 中的图像 1,1
    • Cut the cable tie and unplug the remaining wires.
结论
2等其他人完成本指南。
Jessica Ouyang
于10/08/18注册
619 声望
创作了4篇指南
团队
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 的会员
CPSU-WHITE-F18S15G4
4 名成员
创作了10篇指南
一条评论
Where can I get the circuit boards for the left and right ?
jfsucher - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 30
总计 1,062
